Yesterday my CEL came on for the first time ;) I got code P1115. After research here I see it is a bad O2 sensor after the cat. conv. Do I need to change all the O2 sensors, or just the bad one? Also, how long can I go before I fix it? I was hoping a week would not hurt. One last thing, minutes before the CEL came on I had the GPS removed and some stereo wiring fixed, could that have anything to do with the CEL (wire not grounded, bad connection, etc..)? Thanks :drive:
P1115 Oxygen Sensor Heating Ahead of TWC, Bank 1 – Above Limit
Potential causes:
Heating current too high
– Heating resistance too low
– Short to B+
Heating current too low
– Short to ground
– Corrosion in connector
– Break in wiring except for a few litz wires
Open circuit
– Break in wiring
– Heating resistance too great
Internal resistance of oxygen sensor too high
– Open circuit in sensor line
– Oxygen sensor
Loren, thanks for the detailed response :D This morning I started the car and the CEL stayed on as expedted. I drove half a mile and to my luck the CEL turned off!!! :clapping: Started the car several more times today and it always turns off with the other warning lights (so I know the bulb is good). What could be going on?
O2 sensors can go bad after 60K. Like I said could be a bad connection or a bad sensor. To find out:
Check resistance of oxygen sensor heating.
1. Remove connector of oxygen sensor 1 ahead of TWC.
2. Connect ohmmeter to pin 1 and pin 2 of the oxygen sensor connector towards the oxygen sensor.
Display: < 2.6 Ω at 25 °C
Measure resistance between oxygen sensor housing and oxygen sensor heating.
2. Connect ohmmeter to pin 1 of oxygen sensor housing and oxygen sensor connector towards the oxygen sensor.
Display: ∞=Ω
3. Connect ohmmeter to pin 2 of oxygen sensor housing and oxygen sensor connector towards the oxygen sensor.
Display: ∞=Ω
