After reading the other article in the DYI section about removing the amber lens filter, I looked again at my car...
It looks to me like the only thing that is orange there is the bulb, did this change at some point? Could this be true?
Also, there appears to be a slight haze inside of the head light lens, almost like moisture has dried there leaving spots etc. Is there any safe way to clean this up?
Al
Edited by Westcoaster
Al
Took out the head light assy, yep definitely the amber filter syle on mine, currently a clear bulb with 180 degree pins.
