Model year:2005
Body Style:C2
Transmission:6MT
Parts catalog does not show P/N but shows "matching with cylinder head".
Is it possible to order only cylinder head cover?
It was broken by accident. Therefore I will not be able to charge warranty.
Damage is only headcover. other parts are not damaged.
I'm afraid you are stuck as the cam cover helps hold the cams in alignment with the head - so alignment is critical. Porsche only sells them as a set.
The labor to replace a head and cam cover will be likely be pretty high.
Perhaps you should talk to your dealer and see what they will do for you.
BTW... you are talking about the cam cover (item 7) not the heat shield (item 52) - right?
Thank you very much for your attention.
I am talking about the item 7.
As you pointed out, Porsche recommends matching with cylinder head.
Therefore the cost of parts, which is assy, and labor is very high.
So, I hope to buy only head cover.
