Does anyone know the approximate labor charge (hours) to install a new 996 transmission (6-speed)? And what the dealer list on the transmission is?
TIA ...
Vic
99 C2 cab
I believe it would be more like 8 hours.  That is what it took for my boxster.
IMHO I think you were over-charged. To do a RMS you need to drop the tranny and I know they can do that in under 2 hours. There is no difference - just installing a different transmission and a test drive.
Maybe but that was 2 different quotes. One from a dealer and one from an independent porsche repair shop.
That also includes replacing the clutch though that does not add that much time.
RMS takes longer, because you have to take the flywheel off. 2 hours seems unrealistic. I've seen it done in the factory in Stuttgart and at a Porsche dealership, both times it took about 4-5 hours, and they charge you about 6 hours.
As for the gearbox, there may be light at the end of the tunnel. When I was in Stuttgart before X-mas, they told me that GETRAG (who make the gearbox) will start selling reconditioned gearboxes soon, which will make replacement a lot cheaper.
Cheers,
Uwe
Edited by umn
There is the book labor rate and then how long it takes an experienced mechanic to do the work.
I watched Peter take everything out for a seal replacement on a Boxster. Once the flywheel was out and I could see the leak from the seal I had to leave. I was less than 2 hours.
