Does anyone know how to remove the coolant pump assembly from a 01 boxster? the Pulley has separated from the pump and needs to be replaced.
Edited by machster
Sounds like a power steering pump problem. I would start by taking the cover off the engine and then perhaps the front cover off, that's the one behind the seats. Where is the oil coming from? I think the power steering pump is on the driver's side front of the engine.
