I posted this at rennlist but seems nobody has answers for me,
Can anybody help over here?
Does anybody here know what the compression specs are for a 2002 C4s engine?
I recently had a full maintenance service done on the car,
including a compression test. and my mechanic told me the car looks solid,
and the compression test results were very good.
When I got home, I noticed on the invoice there were some figures for the test results:
#1- 270 psi
#2- 265 psi
#3- 265 psi
#4- 255 psi
#5- 255 psi
#6- 255 psi
I'm curious for comparison, what the numbers would be for a "perfect" engine.
From my experience those numbers look way too high as far as psi goes. As a general rule compression should not vary more than 10% between cylinders.
  • 2 years later...
#1- 270 psi
#2- 265 psi
#3- 265 psi
#4- 255 psi
#5- 255 psi
#6- 255 psi
CosmosC4S,
I have an unmodified MY03 C4S and had a PPI completed when i bought it. Compression was reported at 250psi on each cylinder. Not sure what the 'factory' spec is..If anyone knows ?
