New instrument cluster installed - wrong fuel reading..
Calibration is usually necessary after replacement of the fuel tank, fuel level sensor or instrument cluster. This would especially be true if the new cluster came from a C4 and your car is a C2 (or the other way around C2-C4). This requires removing and refilling with exactly12 liters of fuel. Then using a PST2 (or PIWIS tester) to re-calibrate the cluster.
Thank you for your answer :)
What if I just put the old one back in place, do you think it´ll read correctly?
