It is about a 5-8 hour job depending on your experience level. You will need a spring compressor and a lower balljoint puller.
If this is something you really want to tackle let me know and I can provide more info. Also, remember you will need to get the car re-aligned immediately after. Changing the springs alters the ride height which also alters camber.
