I have a feeling my MAF sensor is going bad... it was just replaced about a year ago (sadly, just more than a year ago, so I can't get it replaced for free under the 1yr parts warranty). I cleaned it with electrical cleaner, but the codes came back after 40 miles. I just wanted to check with you guys before I spring another $300 for a new MAF sensor.
Check your oil bellows, I have the same problem and my mechanic is working on the car today. I will let you know how it goes
So what did you find out?
replacing the air/oil seperator didn't fix it :-/ Code came back after 20 miles....
hm, maybe it did fix it... I reset the codes, drove it 300 miles, and it hasn't come back :thumbup:
