01' Boxster Hydraulic Clutch Adjustment
:huh:I have a 2001 2.7L Boxster with hydraulic clutch.
Does this clutch require periodic adjustment ?
Where and how is the adjustmnet made ?
JA
hi there im a tech in bc there is no adjustment on these clutches it adjusts itself over time if u r experinceing clutch probs it probably needs a new one and make sure u check the flywheel as these tend to be weak after a while but normally u will hear a rattling at low idle sounds like its coming from the trani but its the flywheel normally hope this helps
:welcome:
JA
:welcome:
Thanks to you both Loren and Lenny.
I have no clutch problems at this time - but will bleed the system soon for maintenance .JA
