Greetings all,
New to here and need some of your advises before I send the car to the dealer... :help:
1. The driver front turn signal is not working... checked the bulb and fuse and both seems ok, would it be the electrical problem? or should I just replace the bulb? Everytime I pull the lever to try to make a left turn, it clicks very fast and it's really annoying. The rear one are ok.
2. I have full power seats, everything works except the lumbar support on the driver seat. When I try to adjust it, I can hear the click but doesn't seems to change the position, all 4-ways are not working, could it be some wire/plug is loose under the seat? or is there anything I can check it by myself?
Thanks for your inputs in advance!
Cheers,
JJ
In every car I have ever owned, the rapid flashing of a turn signal was the indication that one of the bulbs (front or rear) on that side was burned out.
You say the bulb "seems ok". How did you check it. Have you tried a known good, or new bulb in that spot?
It's the bottom amber bulb inside the main housing... I will try to swap the bulbs or just replace a new one tonight and see if it works.
  • 6 years later...
Sorry to bring back a nearly 7 year old thread, but I am having the same lumbar support problem as the OP. Anyone know what this could be?
