New Gremlin today. After a 3 day weekend of tracking at Road Atlanta, and opening and closing the top without any problems, I have a fault when I closed the top at home. It seems like it works fine, closed, hook is in, lid is in, but the windows won't go up with the top button depressed. I hear a clicking sound and the top light flashes then stays on.
When opening the top, it seems okay up to the point where the windows go up. Then same clicking sound and flashing. Same issue when using the key in door.
The reservoir is full, and the clicking sound comes from the controller itself. I remove the battery for 15 minutes, and disconnected and removed the controller, reconnected all back and same problem.
Could some switch somewhere not be making contact? The main switch by the pump does make contact. Any thoughts appreciated.
Izzy
