Hi all,
I'm currently looking at buying an '03 Boxster S and have been digging through the ordering guide, option decoder and posts here in order to verify/understand the options on the car. I have just about everything figured out, but want to double check a couple things.
As near as I can tell from the '03 ordering guide, the only way to get Xenon headlights is through the P74 package. Would this show up on the option sticker as P74 or as the separate option codes 601 and 288 for the litronic headlights and headlight washers, respectively?
The sticker lists an option code 239, which best I can come up with is a generic designation for 18" tires. Does this sound right? The car is equipped with option 411 for the 18" Carrera wheels.
Dan W.
I call it the "build" sticker.
Options are marketing speak, the build sticker shows what technically went in when the car is built no matter how they were ordered.
