Hello,
Will 18" Turbo look 1's from a narrow body 996 fit my Boxster? Unfortunately, I don't know what the factory offsets are.....
Thanks in advance,
David
If they are 7 and a half inch or eight inch fronts they'll go straight on. If they are 10 inch backs you'll need an 18 mm spacer. The offsets are 55/50 on the Boxster and 50/65 on the 996 (from memory, it might be 50/55 on the Box but I don't think so). Ideally, you'd be looking for 9 inchers on the back on the Box to get rid of the spacers.
This assumes Porsche wheels and not replicas...
Hi Paul,
Thank you for the reply. Yes, they a factory originals. I've e-mailed the buyer and want to take a look a them before I purchase (if not, no deal). I believe on the inside they'll have a marking w/ the manufacturer and I think these are made by BBS.
Regards,
David
They'll have Porsche numbers, size and offset marked if they are Porsche wheels (e.g my current 996 set are: 993.362.134.06, 7.5J, ET50; 993.362.140.04, 10J, ET65).
  • 4 months later...
Hi Paul,
Thanks for the advice. I bought some used 996 Carrera Sport Design II's (7.5 x 18 and 10 x 18). The rear wheels has 65 mm offsets and I just ordered 18 mm H&R spacers w/ longer wheel bolts. I hope these will fit fine without any rubbing.
Regards,
David
sorry for bumping an old thread.
but this has been bothering me for a while.
isn't installing 996 tire setup on a 986 really bad for handling balance?
seems like this would make the 986 understeer in a serious sort of way.
Hi sorry if this is the wrong place to post this!
I too am looking to buy a set of the following 18in wheels complete with tyres:
993.362.134.06 7.5J x 18 ET50 FRONTS
993.362.140.04 10J x 18 ET65 REARS
I dont know the official name of these wheels I am only have a picture and the part numbers given.
Will these go straight on to my 2.5 late 1998 Boxster? I currently have 17in standard Boxster Alloys.
Thank you.
Lee
Thank you.
Lee
Hey Lee, I've got a set... PM me if interested.
  • 8 years later...
Old Topic same question sorry , but I need to clarify
Does the wheels from a 996
Front 7.5J ET50 x 18
Rear 10j ET65 x 18
Fit a 2.7 Boxster 2000 ? The rear is the real issue. Do I need 25 MM spacer ?
Appreciate any Help :)
ACSF
