Hey Loren. How`s it going? Would you happen to have a DIY on the turbo fuelpressure regulator. I think you have to disconnect the air pump and oil filler neck. Thanks Mike
There isn't really a DIY for that. But to get to the injectors on that side they recommend removing the air pump. I think you just need enough room to get your hand(s) in there.
Thanks for that Loren. Is removing the air pump pretty staight forward??
Remove the secondary air pump:
1. Pull off right connecting hose between charge air cooler and pressure pipe:
· Unclip the locking clips using a screwdriver and pull off the hose.
· Then re−clip the locking clips onto the pressure pipe.
· Ensure correct seating.
2. Remove switch−over valve on the secondary air pump:
· In order to do this, press the locking tabs of the holding clip with a screwdriver in the direction of the secondary air pump
· and at the same time push the switch−over valve to the right and remove.
· Undo upper fastening screw M6 x 10.
3. Undo lower fastening screw M6 x 10.
4. Disconnect the electrical plug connection. Undo air hose and pull off.
5. Lift the secondary air pump out of the engine compartment.
