On my passenger side assembly of the TOP, there is this 1 foot long rod with a red plastic joint...the joint snapped off the ball and is broken....what does this part do for the top?
YES THAT IS EXACTLY WHAT AND HOW IT IS BROKEN ON MY CAR, i seen some on ebay for 53 bucks...is the white plastic version a more sturdy plastic?
It is one of the two push rods that raise and lower the soft top. Search the top section as they have been covered before.
The red version was discontinued several years ago and you can only buy the white version, unless someone has old stock or used parts laying around.
I think the white version is made out of a different type plastic because it has a different "feel" to it.
A few years ago Scott Levy came out with a metal joint. This aftermarket metal version has been discussed as well.
