I'm interested in changing out my drain plugs (oil, transmission, differential). When I spoke to Suncoast they weren't able to identify which parts I needed. They said they replace them so infrequently that they just measure the one they remove and find a replacement based on that. Does anyone know the dimensions so that I don't have to remove my plugs to get a replacement? I don't feel like draining these items by removing the plugs and having the car sit while I get the replacement....
S.
PS--2001 C4
900.219.009.30 engine drain plug -- MSRP $3.10 (as of June 2006)
900.123.106.30 sealing ring -- MSRP $0.37
The parts list does not show either plug (fill or drain) on a 6 speed transmission.
900.124.025.02 front axle drain plug -- MSRP $4.90
Thanks! That was easy. I wonder why Suncoast had such a problem? What do you think about the transmission plug? Any suggestions on how to find the dimensions?
S.
