Hi all,
I've just finished my PSE install, with the control switch. This forum has been so helpful, having read all the posts on the subject it almost felt like I was doing it for the second time.
I haven't got much to add that hasn't already been covered other than if you live somewhere where they salt the roads and you use the car all year round, buy new tailpipe clamps and an assortment of m8 nuts and bolts. Mine is only 30 months old and there was hardly anything left of half the nuts!
I picked up the mufflers, used, from ebay, silly I know but they were really cheap! I checked for rattles/loose baffles before buying but still have a terrible rattle in quiet mode.
I put a vacuum pump onto the circuit this evening and one actuator is solid but the other is very loose, causing the flap valve to flap. The flap part is fine but I think the actuator has failed!
Is this available as a separate part, or is one of the mufflers scrap?
Please say it's available :)
Edited by m5jrh
