I have an '03TT with PCMII. I found the mute lead, but I can't seem to find anything for the phone input. I'm reading that you can wire the input into the PCMII with Cayennes and 997's, but can't seem to get it to work for my '03TT. Any ideas?
I've found that some early PCM2 systems did not support the audio input. The Mute line does work on those, however. You''ll need to use your system's supplied speaker.
Does your sound system also have an amplifier external to the PCM2 ? Like a BOSE system? If no (i.e. if your speakers are driven directly from the PCM2) there are other options.
You're right. My PCM2 does not have the ability to support the audio input, however the Mute line does work. I had to wire the supplied speaker instead. And my system does have the BOSE.
