Interesting problem that has a few of us baffled. PST 2 shows no codes. all air passages are tight, swapped MAF sensor with known good one/disconnected battery for limp home possibility/install evo diverter valves. should see .7 - .8 bar. ANY suggestions applauded-thanks for you time-Mark
I had this exact problem after the winter, it was the wastegate down on the turbo that was a little harsh, after I put a little lubricant on it and forced the arm forwards and backwards a few times it started to go smoth and I saw 0.8 on the bar meter again :)
I hope you have this same fault. GL :)
  • 10 months later...
Did you solve your problem and if so how. I have the same model and year as you do and unfortunately have the same problem
thanks
james
I had this problem too. Mine was a mouse that nested on top of my engine and ate through the knock sensor wire. The motor puts itself into a "protect" mode and would not go over .4 bar. Sure there are no codes?
Good luck
