I had H7 blue lights in my fogs but took them out because they were not bright enough (worse than stock).
I was just wondering whether replacing the passenger side bulb on the ICQ kit solved your problem with the flickering headlight...
I haven't replaced the bulb, but the problem sometimes comes back...
All the best,
Gus
  • Replies 184
  • Created
  • Last Reply
Top Posters In This Topic
All the best,
Gus
Hi Gus,
Replacing the passenger side bulb made the headlight work again with the HID kit, yes, but it did not solve the flickering of the side markers, which are LEDs. The headlights never flickered to begin with, it's just the sides that do.
Is your headlight flickering?
Hi Gus,
No flickering here either...
Just sometimes the passenger wont turn on!
I have to switch it on and off to then get it to work...
I am glad it worked for you. I should probably consider buying one new bulb from ICQ.
I have had the kit way past 1 year, so no way they will replace the bulb.
much brighter than halogen, even brighter than silver star.
good enough to almost fool U to think that it's a HID system. LOL
Euro Dezigns H7 8500K 55W
These look interesting - how bright are they compared to stock / halogen and/or compared to HID lights?
  • 9 months later...
After about a year my driver's side wouldn't always light first try. Seemed to be getting worse.
I contacted CQ (5000 K kit) and they said to send the components in and they could be tested.
I said I didn't fancy having my car torn apart for a month.
They suggested that I buy a motorcycle kit (one side) and swap out the components.
I asked if everything was the same and they assured me that it was. Wrong - the kit had been
redesigned/improved (better) and none of the plugs were the same. I installed it and it works ok.
I sent the original parts back immediately. CQ gave me a return authorization number and assured
me that I would receive a credit ($92.00).
Now, 2 months later and no refund. I emailed them and have never received a response.
My move (again)?
My move (again)?
go pick up a new set from ddmtuning.com
that's where i got mine.. they're $29 i believe now for the set, with lifetime warranty... or a couple bucks more for slim ballasts (that's what i got)
  • 6 months later...
My move (again)?
Now 6 months later and MANY emails. No response whatsoever.
  • 5 weeks later...
Hello all, question can you modify to upgrade halogeen w/o projector lensen to halogeen projector lensen by only upgrading the lens? or do you need to buy the entire unit?
  • 4 weeks later...
My move (again)?
Still nothing (Aug 1, 2010)
so how many of you actually installed aftermarket hid kits with the slim ballasts and just stuffed everything inside the housing of your boxster 986? im concerned with with heat if i do it this way rather the drill-a-hole method. how hot do the slim ballsts typically get?
Edited by battouter
