My 2000 Boxster 2.7L, 5 sp, 40 k mi., just failed DC inspection because the OBD reported code P0760 "Shift solenoid C." The CEL is not illuminated.
First, isn't there a forum or section from which contributing memebrs can get access to code definitions? I looked but could not find. Anyhow, what's this code and what's shift solenoid "C" do?
Just to note that I finally found the codes list (in "Online Docs Menu"), and there's no P0760 listed in any of the sections.
The P07xx codes seem to relate to tiptronic fault codes - seems crazy if yours is manual. Have you tried clearing the code to see if it comes back? (Not that I would know what to suggest if it does).
