Ran to the local Auto Z last night to get the codes from my car. Had a total of 4 that is a lot.
I am looking for a little help on a fix for these. I have looked up the codes in the Bentley manual but I really don't know where to go from there.
The car is a 98 54,000 miles. Short throw, Powerchip, Evo Intake, and B&B Exhaust. I cleaned the MAF about 4 months ago with contact cleaner, maybe I need a new one?
Anyway the codes are:
P0410
P1411
P1125
P1123
Any help is appreciated.. :help:
P0410 Secondary Air Injection System - Signal Implausible (Cylinders 1 - 3)
P1411 Secondary Air Injection System - Signal Implausible (Cylinders 4 - 6)
P1123 Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Lean Threshold
P1125 Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Lean Threshold
I suggest you solve each set one at a time.
First two say the air pump is not either runnning or one of the lines is plugged/leaking.
