Firstly I've read and searched a lot on these forums. So any questions I have are due to stuff I could not find.
MY 2000 Boxster S.
This will be my first brake job. I am planning to do front + back, pads, rotors, fluid flush.
My brake lights have not come on yet, looks like the pads have 3-4mm left in front and rear. The rotors are at 22 and 25mm.
I have 4 new zimmerman rotors, 2 new rear pads (2 front ones come in another week), and ATE blue and amber fluids.
Questions:
-I think I need to paint the rotors. Where do I spray the paint? front and back? whole rotor? Should I cover the disc area with painters tape?
-Can I use the old front pads with the new front rotor for a week or so until I get my new pads?
-What order should I do stuff in? Flush, then rotors, then pads?
-Any wierd tools that I will need? I will have a helper thus won't need a powerbleeder.
-The new pads are Hawk HPS (Should get them in a few days). Do I need to drill holes for the sensor? If so, how do I do that? Do I need special tools?
-Anything else I should know? I will be following the Bombay digitial tutorial as well as Loren's tutorial.
