All,
I have had my 2006 Boxster S to the dealer 3 times now for a problem with the top. I would love to know if anyone else has had this problem and if so what was the resolution.
The problem is that there is a plastic bar in the back of the top that attached to two clips (under the top cover)
When I operate the top, these clips break and this bar drops down and rests on the motor cover. I am told this bar is there to aid in water drainage and direct water to the outer drain areas. When the top is closed this bar also gives tension on a flap that pulls on the bottom of the read window to give it tension.
I am now going in to the dealer in friday as they claim they now have to replace the entire headliner.
I have also called PCNA and filed an investigation.
Any evidence of another having this problem and what was done to resolve it would be great.
THanks
Darius
  • 11 months later...
Are you talking about the rain rail? Mine is doing that too. Did you ever get a solution?
All,
THanks
Darius
Edited by type987s
Kind of. PM Me if you get this and I can discuss with you.
Darius
All,
THanks
Darius
