I have currently a CDR22 installed in my C4 -99. Is it possible to change to a CDR23 without any other changes than disconnect the old and plug in the CDR23 ?
I have the button peel on my CDR22 unit as well as some funny behavior of the CD player (works fine in abot one hour, then the left channel starts to make noice as when you have a bad radio reception, when switching over to radio mode directly everything works perfect!) and the swedish Becker service wants more to service the unit than I would be able to by a used CDR23 unit for.
As far as I can understand, CDR23 does not fit MY99. CDR23 only fit fiber cable from MY03 and UP. You may want to try aftermarket unit if the head unit is bad. Becker is not a "good" unit anyway. I wish I can change my CDR23 easily for aftermarket unit but the fiber cable prevents me from doing so.
Please correct me if I am wrong. My CDR23 behaves weirdly but dealer doesn't want to change one for me unless it is dead.
Good luck!!
