So a week ago the airbag warning light came on, so I took my 01' C2 to the dealership to have it inspected. They found that the airbag relay was bad and needed to be replaced. I was quoted $622 for the relay and labor. I asked if the airbags were inoperative, and was told it was a roll of the dice.
Question 1: $622????????? Last I checked relays were not that expensive! And it is not like it is located inside the engine block!
Question two: Is it really a roll of the dice?
Thanks in advance!
-Sean
Airbag relay? Not on this car. I concur with Tool Pants perhaps they mean control unit.
I really hope they ran their PST2 on the car and the problem is not a seat belt buckle or ground under the seats - which is very very common. If they will tell, you ask what the airbag fault code is. If they won't tell you, I would find another dealer/shop.
Fault code 46 - Driver's belt buckle
Possible cause of fault
. Incorrect coding
. Short circuit to B+/ground or open circuit in the wiring between the driver's belt buckle and the airbag triggering unit
. Driver's belt buckle faulty
. Triggering unit for airbag faulty
The airbag triggering unit is: 996.618.219.02 with an MSRP of $481.36 (as of June 2006)
  • 4 weeks later...
. Incorrect coding
Thank you all for your help!
-SD
