MY 2000 Boxster S with 32000 miles. I noticed fluid leaking from the left rear suspension area. Starting at the last spring rung and going down the strut housing, there is caked dirt that is "wet". Are the stock struts gas or hydraulic? Do these commonly fail like this? Or is this something else? I checked the brake lines and caliper. The backside was covered with the same stuff as the strut, so I'm not sure where its coming from at this point.
thanks
Tommy
thanks for the feedback.
That DIY is excellent.
Between this and the CV joints, sounds like I'm going to get good at suspension work.
Tommy
  • 4 weeks later...
Was there more than one type of shock available on the 2000 Boxster S?
What option code should I be looking for and where will I find it?
thanks
Tommy
