My low beam went out on the passenger side so I replaced the bulb and still no low beam (high beams do work). Then I checked the fuses and that's also good. Now I'm stuck does anyone no what the next step is?
Pull out the headlight. There is a male connector on the rear of the black plastic headlight mounting bracket. Push on that connector with your finger and make sure it does not push back.
