I need to install a trailer hitch on my 06 turbo. Two questions: 1- is there some sort of template for cutting through the rear bumper? 2- what do you use to cut through the painted bumper without trashing the thing? Thank you for any help!
1. There is a template on the underside of the bumper. You will see it when you remove the bumper.
2. Use a jigsaw with a fine blade.
I installed it a couple months ago and it is a PITA!
  • 4 months later...
Did you do the hitch install on your Turbo by yourself or did you have it done at a shop? Did you order the hitch through Porsche or after maket retailer?
I need to put one on my 05 Turbo. Any advice appreciated.
Jon
