Search the Community
Showing results for tags 'water pump'.
  • Search By Tags
    • water pump ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 13 results
  1. Hi guys.Finnally got the Boxster on the road after an enforced year stood.It sounded a bit rattly when I started it up.I have done about 50 miles in it since all short journeys, and it still making the same noise.Not knowing much about these engines not sure if it's something more serious than tappe...
  2. I recently had to replace the water pump on my 2001 Boxster. This all went fine, however, the red light to the right of the temperature gauge is blinking at 1 Hz. I've read this indicates low coolant level. I followed the factory procedure to bleed the system and it is filled to the max, but the...
  3. Late 2004 Boxster Base Tiptronic with 45,000 miles I have racked up 15,000 miles over the last 3 years of ownership. The coolant was flushed about a year prior to purchase. I think it's time to flush the coolant. I plan to buy the Airlift tool - it's a time vs cost issue, time wins....
  4. Are GEBA and PIEBURG water pumps OEM?
  5. 2005 C2S ~52k miles For the record, for multiple months prior to these maintenance procedures, I noted an oil temperature of about 205 deg F, whether the ambient temperature was warm or cold. I could get the temp to go up by keeping the RPMs above 3000 for an extended time. Most of the time the...
  6. Am I unlucky.. :huh: Seems that after fixing my oil level sensor, I've found that the coolant pump squeaks when the car warms up. I've localized the noise to the pump rather than the idler pulley so it is looking like I'm going to have to get it replaced. 56k miles seems awfully early for the water...
  7. Hey all, Looking for some help here. I developed a pretty bad coolant leak about a month ago, i was losing about 1 liter per week. When I got under the car i saw the dripping coming from the tip of the waterpump, and surrounding areas. Since the car had gone about 60k since it was last replaced...
  8. '99 c2 6spd 167000mi Okay guys, Finally got my new water pump up on the engine. I go to torque the bolts and I get around to the last bolt only to have it bottom out! I jump back into the porsche parts Katalogue and sure enough it lists a 30mm and 25mm long bolt! can somebody illustrate for me whi...
  9. Found a small spotting of coolant dead center of engine at rear under cats and in front of pulleys . Thought it was water pump related, but turns out its the part that the coolant drain plug is cast into. Picture attached should help identify this. What is this pump housing part called? For now we J...
  10. I know this is a topic often reviewed here on the forum but I was looking for a little more help prior to just letting my local mechanic ream me for a few thousand dollars. Use the forum often, rarely (if ever) post, but have been far more active on equivalent sites for cars I've owned in past (Audi...
  11. I have a 2003 Boxster with 77,653 miles. I am the third owner and this Tiptronic Porsche was brand new in late December 2002. It is my daily driver and most of its miles are on the highway. It hasn't been tracked. Roughly two weeks ago the coolant temperature blinking light came on for roughly...
  12. '04 CTT w/ 83K miles I had a knocking noise coming from the vicinity of the water pump; it was audible at idle when standing near the hood. Took me about 6 hours, it wasn't hard, but there are some frustrating parts due to the tightness of the space between the radiator fans and the drive belt...
  13. My Water Pump was leaking coolant on my 1998 Boxster, so I decided to replace the water pump gasket. After removing all the components described in Wayne's Technical Article of Water Pump and Thermostat Replacement, I came across one unforgiving bolt on the Water Pump that would not budge. The 10m...
