Search the Community
Showing results for tags 'voltage low'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. I want to share an experience I had with my 2002 996. For the past several months, after a cold start, my initial volts held steady at 13.8v indicated. As I drove around, I had problems with the voltage dropping to 12.5-13 volts without any accessories turned on after the car reached operating temperatures ~180 degrees. Once I turned on the A/C, the volts dropped below 12. This has left me having to jump the car a few times. First thoughts typically range from a bad battery, alternator to starter. Like many, I headed to the local parts store to have the battery, alternator and starter tested - all passed. Second reaction is to clean the terminals on the battery and grounding points, yet the problem persists and leave a few scratching their heads. I checked voltage drops between components, I checked for AC volts to see if I had a bad diode, and recharged my battery. In my research, Porsche 996/997s have a well known issue within the community that the positive wiring from the junction box to the starter to the alternator tend to go bad prematurely - corrosion typically seen on the starter wiring. What happens as I understand it is that when the car is cool, the wire coming off the starter is cool and electrons flow fairly easily (note the initial 13.8v at start up). As the car heats up, so does this wire and in doing so, the heat coupled with the corrosion reduces the overall voltage/amps going to the alternator making the alternator operate sub optimally thereby reducing available voltage at operating temperatures (12.5-13v). When the accessories are turned on, more volts/amps are needed, but the alternator is struggling to put it out while maintaining the average 13.8-14.2v seen on healthy cars. I pulled the alternator and starter to have them tested independently removed from the car. In doing so, I visually inspected the wiring harness connecting these components. As I did this, I noticed pretty bad corrosion on the wire coming off the starter as you can see in the pictures. I knew immediately what my problem was given an all 'pass' on my battery, alternator, and starter at the parts store. I ordered a replacement. Even though my problem was pretty obvious after seeing the wire, I recommend getting the individual parts tested as they will be out anyway when replacing the wire. It's still good practice to clean all the grounding points (engine to chassis, battery terminals, etc). I hopes this helps others having similar problems. Ken
