Search the Community
Showing results for tags 'vacuum hose'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 2 results
  1. I need some help reconnecting the vacuum hoses on my '03. Had to remove tiptronic to repair it, and either have a broken vacuum hose, and/or am as lost as I can be. I can't figure it out. Here is the vacuum diagram from the trunk. Part of the problem is, that I can't identify all the parts. The "white" connector goes into the intake. Off of that is a "Y". The "Yellow" line (vacuum hose) goes nowhere that I can tell. I am sure it connects somewhere, I just can't tell where. It is long. The "Pink" end of the "Y" is open. I am sure something sticks in there, just not too sure what. The "Green" line (vacuum hose) connects to what I believe is the Resonance Flap Valve. However, it is either broken (and connects with the "Blue" line (vacuum hose)), or inserts into the "Pink" end of the "Y". Not too sure which. The other end of the "Blue" line (vacuum hose) connects to a 4 way "Cross fitting", that connects to the vacuum reservoir. Shown as connection #1 below. I guess the upper end of the "Blue line" (vacuum hose) could connect to the "Pink" arm of the "Y". Again, not too sure. It is entirely possible, that the "Blue" and "Green" line is a broken line. If this is the case, not too sure what would plug into the "Pink" on the "Y". #2 "White" line (vacuum line) attaches to a switch, that I believe is associated with the tiptronic transmission. The lower end of the hose connects to the "Cross" fitting that is by the vacuum reservoir. The "Purple" line (vacuum line) is attached to a valve that controls coolant that goes to the tiptronic. #3 Line disappears somewhere deep into the engine somewhere. Can anyone help? Thanks!
  2. Hi, I am relatively new to the Porsche world. I bought a '99 996 about 2 years ago, and it has been running like a charm until recently. Earlier this year I moved from FL to NC, where winter exists. Around the time the temperature started getting near 40 degrees (which rarely happened in Florida), the engine starting exhibiting a very rough idle when starting cold. I got a code for a bad o2 sensor, but fixing that didn't seem to resolve the problem. No other codes, so I started going through a checklist of things to replace: MAF, coil packs, spark plugs. I cleaned out the throttle body. Nothing seemed to help the situation. Right before Christmas, my alternator died. I got a new one on Friday, and put it in today. In doing so, I noticed that there was a small crack in this hose: What is this hose and could it be responsible for rough cold idles? Also, what does it connect to and how hard is it to replace it?
