Search the Community
Showing results for tags 'throttle body'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 5 results
  1. vintage 1997 Boxster.... Shortly after I changed the oil, the revolutions at idle began to oscillate between 300 rpm to about 1200 rpm. Reading various forums identified the most common problem is a dirty throttle body, possibly the Oil Air Separator (OAS). Given the car has 34K miles and cleaning the TB has never been done, I figured it was time. The throttle body was indeed filthy with a very light oil-like coating, and same for the plenum to the cylinders. Having seen pictures of the effects of a bad oil separator, I figured mine was ok and what I observed was just buildup of 34K miles. After a through cleaning I reassembled the TB and remounted it (what a PITA that was because each side of the 'T' plenum would not line up with their respective intake manifold). What a struggle. Finally got it beat into submission and connected the vacuum lines and this is where I need some help. Standing behind the engine, on the extreme RHS there is a vacuum line with what looks like a check valve that goes into the RHS plenum. Got that inserted although is seems rather loose. Now, on the LHS at the rear, when I had removed the TB, I noticed a very small (less the 1/8" OD), thin black hose about 6" long that was adjacent to the hydraulic fluid reservoir - I don't recall if I pulled this out of the 'T' plenum or where is should be plugged. Can anyone offer any suggestions? Perhaps a drawing showing the vacuum lines attached the the TB plenum? The car seems to run OK after the cleaning and I do not notice any strange behavior. Insight much appreciated. John
  2. I'm new to Renntech and hopefully I follow the decorum correctly. If not I apologize. Anyway, I have a 2000 Boxster S. It has been sputtering on take off and gave codes that suggested the MAF was out. I disconnected the MAF wiring and it greatly improved the performance. I ordered a MAF and by the time it came in I believe my car went into Limp Mode. I installed the new MAF and cleaned the throttle body but it still acts like it is in limp mode. I also changed the spark plugs hoping this would help. The only code I'm getting off it now is P1118 and also the codes for missing on cylinders 2 and 3. Is it possible that is simply still in limp mode? If so is there a way for me to reset it?
  3. So I was watching a YouTube video on how to clean my throttle body. It was very thorough except for one thing. It never mentioned anything about the two small tubes that insert into the gasket that connects the plenum to the intake manifolds. I've searched and can find no info on what these tubes are. I snapped one and am not looking forward to trying to run a new one. If I could just leave it off that would be best.
  4. I noticed that the part number for the e-gas throttle body was superseded to a 997 part for the Bosch throttle body. The old part being 99660511501 and new 99760511500. Are they interchangeable without needing a DME update? Mac
  5. I have a 1999 Boxster with 85k miles on it. Due to some rough idling, I decided to clean out the MAF sensor and the throttle body. After reading online and in books on how to remove the throtte body, I was successful. However after removing it I noticed a small tube tree that connects to the throttle body. Looking at diagrams online I never see this tube referenced. Anyone know what this tube is and if it is supposed to connect to something?
