Search the Community
Showing results for tags 'starting issue'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 2 results
  1. Hi Hi, I could use some help. My Boxster left me stranded at a light. Would crank but not start. After checking fuel pump fuse was ok I had it towed home. I jumpered pins 30 and 87 on fuel pump relay and it started. Ordered relay from Pelican. Installed, it started, drove 5 miles to an appointment, then would not restart. Towed home. Before I hooked up Durametric I tried ignition and it started. Durametric revealed 6 codes. The first one has been ongoing. The last 5 are new. P0455:Porsche fault code 94 - Tank vent system (major leak) P1130:Porsche fault code 361 - Oxygen sensing adaptation idle range bank 2 P1341:Porsche fault code 174 - Camshaft adjustment bank 1 below limit value P1579:Porsche fault code 111 - Crankshaft sensor P0336:Porsche fault code 110 - Engine speed sensor Open circuit P1124:Porsche fault code 167 - Fuel pump relay below limit value Regarding the first ongoing code, I've replaced the gas cap, carbon canister, vacuum canister, secondary air vac valve, 2 check valves. Still got that code but was running fine so I ignored it awaiting more insight. Also I've replaced the fuel filter less than 10,000 miles ago. I did not think to unhook maf during start failure. I did replace it within 10,000 miles though. It was running normal prior to problem. I did detect a very slight miss at idle similar to when I had a hairline crack in a coil pack. Any help would be greatly appreciated. Thanks, Garry
  2. Recently on my 2005 CTT when I try to start the car it would CLICK but not start. On the second try the starter will engage? Any thoughts. I read battery? Thanks in advance.
