Search the Community
Showing results for tags 'starter motor'.
  • Search By Tags
    • starter motor ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 2 results
  1. I need a second opinion. For the past 5 or 6 months, in the hot or cold, my Pepper would struggle to turnover, but only sometimes. I was convinced the battery was on its way out. I replaced the battery with an Interstate, then I hooked it up to a trickle charger to make sure it was fully charged....
  2. Hi Fellow boxsterites I need new starter motor for my 1998 boxster r/h drive 5 sp manual have seen 2 types 1.1kw and 1.7 kw now the 1.7 kw high output is apparently 1" longer would this still fit ok.......... please advise and also having the extra output wouldnt jepardise anything ???? and ple...
