Search the Community
Showing results for tags 'spoiler wing'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 2 results
  1. Hello , I have a 2001 carrera and the rear spolier is stuck in the up position. I boosted a dead battery and shortly after i notice the wing came up on its own while it was in park.Something must of happened during the boost. Has anyone ever experience this? I thought after i took it for a ride it would go down, no such luck. So i have no idea how to start to diagnose this problem or where to look. Nearest porshe dealership is about 500 miles from me... Can anyone give me some pointers? I also changed the battery.the battery was completely dead and wouldnt even boost later that day. Any help please?
  2. As many of you know, I've started a company to sell electric spoiler ram (eRams) kits for the 996 and 997 turbos - replacing the finicky yet over-engineered hydraulic system. It does away with all hydraulics. Anyhow, I'm playing with the logic that was ultimately programmed into the ECU. I'm wondering if there is a way to get the logic from Porsche? Or perhaps someone here has some better insight? At this point it seems to me as something like this: To raise wing: 1. Momentary push of switch or cluster speedo (75 MPH) signal to ECU to raise spoiler. 2. ECU send current to relay 1 coil which activates motor in one direction. 3. Wing travels up and closed circuit from top limit switch (passenger side ram on top) within ~14 seconds. If no limit switch contact - then WARNING at cluster. ALSO...Wing will not go down either by switch or cluster speedo (37 MPG) signal from ECU to lower spoiler. Similarly to lower wing: 1. ONLY for cluster speedo (37 MPH) signal to ECU to lower spoiler. 2. ECU send signal to relay 2 coil which activates motor in other direction. 3. Wing travels down and closed circuit from bottom limit switch (passenger side ram on bottom) within ??? seconds. **this is different than "UP" as the push to lower switch can be let go at some point before the wing is fully down. Therefor the time-out counter only works with the speedo signal... If no bottom limit switch contact - then WARNING at cluster Not sure if the wing will go up "at next signal to raise" unless fault is cleared (cycle key off). Any info out there?? I'm also wondering if there was a logic change between '01 and '02 model years. There seems to be two wiring diagrams out there for them.
