Search the Community
Showing results for tags 'rear subframe'.
  • Search By Tags
    • rear subframe ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 1 result
  1. Hi all Finally decided to do the clutch. Raised the back of the car and removed plastic covers - all good so far. Then tried to remove the sway bar to fit an engine support brace. The bolts holding the sway bar bushes to the subframe all eventually sheared off - even with WD40, tapping with a h...
