Search the Community
Showing results for tags 'radiator fan'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 3 results
  1. My 2005 C2S 997.1 has been sitting for a few months. It has been on a CTEK battery maintainer. I took it out for a one hour drive today. Just after engine startup, at the end of the drive, and another engine startup after a two hour rest in the garage (water temp gage showing about 120degF), it exhibited symptoms I'd not seen before. Immediately at startup with a cold engine, the engine compartment fan came on and stayed on. About 30 seconds after engine startup, both cold engine and warm engine, both radiator fans came on and stayed on. I have a Durametric and captured the following fault codes while the engine was running (I traversed every menu item on the left of app window): C140 C141 C131 C152 (I think this is due to the inactivation and removal of the PASM module when I converted to coilovers) 8004 8028 8029 8042 FWIW, I was not in ECO mode so the air conditioner compressor was probably running. I was trying to recirculate the freon and oil. (I usually run in ECO mode.) FWIW, there's no CEL indicator showing on the instrument display. Engine water temp about 105degF. Started engine. Engine compartment fan is on. Within 30 seconds both radiator fans roaring (seemingly like they are on high). Using Durametric, went to Front/Activations and found 3 "Radiator fans" (not sure why there's 3). See pic below. First entry - clicked STOP. Nothing happened. Second entry - clicked STOP. Nothing happened. Third entry - clicked STOP. Nothing happened. First entry - clicked START. One of the front fans (or maybe both, it got quiet) slowly spun down and then 10 seconds later it went back to high. Second entry - clicked START. One of the front fans (or maybe both, it got quiet) slowly spun down and then 10 seconds later it went back to high. Third entry - clicked START. Nothing happened. Toggling the ECO button on the climate control didn't seem to make any difference. Gas has Stabil in it. Battery's installation date is July 2014. Yesterday, after the battery-maintained multi-month inactivity, the car acted OK - normal starter rotation speed and fire-up time. Today, battery's voltage after sitting all night, NOT on the battery maintainer, is 12.67v. Why might these fans be acting abnormally?
  2. I'm trying to understand the outputs of the 997.1 cooling fan control unit. I understand that the fans are a continuously variable type and run in proportion to the cooling water temperature. How is the fan speed adjusted? For example, is the voltage adjusted by the control unit? Maybe 0v to get 0 RPM, to 12v to get max RPM. Or, PWM? I'm interested in using this info to add a manual override to be able to run the fan at max speed by a dash switch (but maybe needing some "smarts" if PWM is involved).
  3. So recently i got the P480 code. Fan was running non stop on high. When i turned the car off it kept running on high so i pulled the fuse and went to bed. In the morning i threw in the fuse and the fan didn't run.....turned the car on (Cold) and after a few seconds went to high again. Turned off the car and it ran on high for a while then shut off. So i had to do a bunch of work anyways so i pulled the fan assembly, here are the steps i've done so far: AC fan works fine, this is only the main fan. If i power the fan without connecting to the car (the small wires arent receiving signal) the fan stays off (which i think is good). If i measure the car harness side, it shows the standard 12v and 0v on the plug. The signal wires show ~.3V and 12V My guess was the 12v was the cause of the fan running. To rule out the temp sensor i unplugged it, but the 12v signal was still there. plugged the fan in anyways and it was still running. I did notice when it was unplugged the car only shows as "normal" temp, it didn't peg to the top like i'd think it would. Finally i found that F10 is the signal (Fan Final Stage) Anyone have the wiring diagram or know where this 12v is coming from? I'm 99% positive it does NOT come from the main coolant sensor. And i'm also 99% my fan is working correctly, but i don't have the "before" voltage check to know for sure. Any help would be appreciated. THanks
