Search the Community
Showing results for tags 'psm failure workshop'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 2 results
  1. Hello, Any help on this would be appreciated. Thanks in advance. This is my first post and I will try to be as specific as I can. SORRY if it seems long. I have a base model cayenne 2004 with 89,000 miles. I have always been good about the upkeep... Just changed oil, oil and air filter 2 days ago. For a few months now I have been getting the 4WD system faulty and the PSM failure workshop codes. The codes usually do not come up right away upon starting the car. They pretty much always come up in the middle of a drive at various speeds. I could be on the highway or at city speeds. The codes ALWAYS come up together, which makes me think they could be related? 4WD first and then PSM immediately after. (The 4WD definitely works however. I just moved from Minnesota and drove through the mountains in Denver with the car. I had no issues with the car losing traction. It honestly plowed through the ice and snow like a boss!) The small icon on the dash will also stay lit (a triangle with exclamation point in middle with circle arrow around it.) Next time I go to start the car it is gone. I have not noticed any problems with the car while driving. To me it seems perfectly fine and drives the same the first day I bought it. I looked at the previous forums on this problem but I never saw an actual solution? The guy just gave up and sold it. Other users mentioned it could be the battery. I just had my battery checked and was told it is still good. My FM transmitter also checks the voltage every time I plug it in (basically every time I drive) and always says the voltage is normal. I took it to a mechanic and he said it would have to be diagnosed by the Porsche dealership. He told me this because he said he does not want to waste my time and suspect the wrong part to replace if that is not really the issue. He said it is really hard to diagnose these cars without the bench only the dealership has. He did give me the exact codes which I can list later once I grab the paper from the glovebox. So basically, he got the codes for me and gave me some more transmission fluid which he said was a little low. He cleared the codes for me and charged me $75 dollars. Seems stupid considering I still have the issue and now have to go to the dealership next Friday to get proper diagnosis. But, at least he did not charge me original diagnosis for $145... Anyways, the codes are still coming up after the guy cleared them. Let me know if you have any input on the situation or if you could link a similar forum where the user listed the solution that would be fine as well. SIDE NOTE: I am also receiving the message system key faulty. My mechanic in Minnesota said that was simply due to the weight of the key in the ignition moving around. He said it was no big deal and does not affect the car mechanically. The previous owner bought 2 new key fobs about 1 year ago. This happens with both keys. I have one with a lanyard and keychain on it that I use regularly and the other is just the fob itself. Can anyone confirm that this is true? I know it seems small but it is kind of annoying to hear it pop up often. I'm sure the dealership will give me the info I need and I can update this post after the diagnosis Friday. If any of you smart Porsche pals can point me in the right direction before the appointment I can at least prepare myself for what I'm getting into lol.
  2. Car: Cayenne turbo 2004, 250 000 km The problems have been cascading over the summer, starting with a trashed rubber bushing on the cardan shaft support bearing. Before I got home and could fix that (thanks to a great description found in this forum!), the PSM and ABS lights went on. I guessed it was caused by the occasional knocking and wobbling of the cardan shaft. After fixing the support bearing, the lights stayed on, so I bought an iCarSoft POR II to read fault codes. For some reason, it couldn’t pull codes from the PSM, but there was a fault code in the gearbox controller, about a lack of speed signal from the rear left hand wheel. I gladly bought a new ABS sensor and replaced it, with no luck. I could remove that fault code but the lights returned and I still couldn’t pull codes from the PSM. Next, I lifted the floor mats and found a lot of water on the passenger side from a blocked sunroof drain. Much of the wiring was corroded, so I carefully replaced it wire by wire. At the same time, I put in a new battery since the old one was really weak. The car started and ran fine, but the PSM and ABS lights kept coming back. Next, I wanted to inspect the PSM, so I lifted the plastic cover beneath the wind shield and disconnected the DME in order to get down to the PSM. The PSM connector looked fine without any traces of corrosion. The same was true for both DME connectors. I just brushed off some dust and put everything back together. Here’s where my biggest problem occurred: now my car won’t crank the engine at all. When I turn the key, the instrument screen says that “daylight running lights are not active” or something similar. The cooling fans revv up to max but nothing more happens. i have tried disconnecting the battery for an hour and then reconnecting again without any different behavior. Any ideas on how I can bring my car back to life again? Regards, Niklas in Sweden
