Search the Community
Showing results for tags 'psm failure'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 3 results
  1. 14 Cayenne Turbo S has numerous system failures. PSM codes won’t clear. Right front ABS wheel speed sensor fail message and replaced all four with new sensors still won’t clear. Replaced all plugs, coil packs and the MAP sensor as well as battery (coded battery properly). Thinking it may be wiring harness or ABS control module since PSM failure could be caused by anything within ABS system failure which will fail multiple other systems. any ideas will help as I have very few at this point. Spent $2000 at stealership already abd have determined they are only as good as the technicians they employ as the Porsche training and certification process is pathetic and only teaches how to use PIWIS to interrogate the computers and teaches very little actual critical thinking or troubleshooting skills never mind anything about how the Porsche systems actually function or how the modules work with each other!
  2. Hi, I have a 2005 Boxster S. This weekend while I was away, there was a storm. My kid called and told me that lights were on and the windows about a quarter way down. I came home to windows in the position they go when putting the top down, spoiler up, and a dead battery. After charging and reconnecting the battery, the brake and reverse lights were constantly on and display started rolling through the failures: spoiler controller, psm, pasm, system fault, convertible top not in limit, etc. Various things are clicking and windows move randomly... Where do I even start to trouble shoot this?? Am I totally screwed???
  3. 2002 Carrera 4S. I did a search and didn't see these exact symptoms simultaneously. See attached picture. I was driving at 5k RPM in 3rd when the power of the car was suddenly reduced (by the computer I believe) and the console beeped displaying the following 4 checks: 1. Brake distribution 2. PSM failure 3. ABS failure 4. Battery -- also, as you can see in the pic, the battery voltage meter is maxing out. When I disengage the clutch from the engine the voltage drops some (and the brake/PSM/ABS messages go away and are temporarily ok) but is still running significantly higher than what I'm used to seeing. Could this high voltage be damaging to the electronics system? Presumably there's something going on with the voltage regulator. Does the ABS/PSM turn off automatically for saftey when there are voltage spikes? My battery is an Interstate and is ~ 1yr old. This seems to me like the alternator (possibly the voltage regulator). I realize it would be better if I had a Durametric to hook it up to and get the exact error codes off of. That may need to be done to properly diagnose what's going on here. Thanks in advance for any help/input. Cheers, Alex
