Search the Community
Showing results for tags 'power steering lines'.
  • Search By Tags
    • power steering lines ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 1 result
  1. Curious if anyone knows if these two lines can be replaced / accessed through the right rear fender area? If not, then will I be able to achieve this by removing the AC? I need to replace these two hard lines that connect hoses to the lines that run along the bottom of the car up to the rack & pinio...
