Search the Community
Showing results for tags 'p1318'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 2 results
  1. 1999, 996, 117k miles Due to leaking I recently changed my coolant reservoir tank, which involved disconnecting and re connecting 2 fuel lines.. Upon restarting the car I had a rough idle and CEL. I purchased a $100b code reader, read a bunch of stuff online and decided to clean the MAF sensor, change the air filter, spark plugs, plug tubes and coils. upon today's startup I get an erratic/rough/low rpm idle, flashing CEL and the following codes: P0102 mass air flow circuit low P1319 misfire emission related P1318 misfire cylinder 6 emission related P1315 misfire cylinder 3 emission related P1313 misfire cylinder 1 emission related Somehow I went from a leaky tank to some bad stuff based on a do-it-myself moment. I wonder if the coil packs might not be perfectly seated? I'm thinking a new mass air flow sensor and all four O2 sensors need replacing?? Please advise. Hugo Kohl
  2. Hi all The engine light comes on my 996 every so often, then goes off a few weeks later. I wasn't to concerned as the car drives well. So I got round to plugging it into the Durametric to look at the fault codes.... I've got loads of codes, P1340, P1531, P0300, P0306, P0304, P0305, P1585, P1319, P1318, P 1316, P1317, P0301, P0303! The car drives very nicely, loads of power and seems perfect when accelerating and driving. Feels perfect on the open road. The issue I have is a "tapping" noise on the engine on idle and a slightly eratic idle - its not much, but its not perfect. It sounds a bit like my 1955 VW Beetle. I was running 5W oil, but also changed it to 10w a month ago, but the tapping noise is exactly the same. Car has done 96,000m. So I'm keen to look at the codes and fix as many things as possible! So today I removed the spark plug/Coil pack covers on both sides to remove a spark plug from each side, the idea was that I could inspect them and the coil packs to see if there old or visually worn out. The plugs were NGK FGR6KQE 4 tipped plugs, with BERU coil packs all round. The plugs both looked great, normal grey/brown looking colours. The coil packs were dated Jan 2013 and visually looked clean and tidy. **I've owned the car about 18 months**. I was hoping the plugs may look old and I could just replace those to see if it improves, a fair £40 and Id get to spend some time hopefully improving the 996. I noticed that one of the middle "tubes" where the spark plug goes into was a bit wet with oil - the other two were dry. I see that its possible to buy new tubes for about £8 with the o-ring seals. The 3 tubes on the other side all looked dry, so just one that's seeping it seems. I'll work my way through the list of codes, but if anyone has any advice on these codes id love to hear from you! I see one of them was for a fuel vent, so I'm hoping a couple of codes could be cheap fixes. Many thanks, Paul Dorset.
