Search the Community
Showing results for tags 'p1120'.
  • Search By Tags
    • p1120 ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 1 result
  1. What could be causing the attached faults simultaneously? I parked the car last night - this morning it would not start. I checked and cleaned (contact spray) the DME connectors to no avail. In the past, I had a few occasions when the throttle would "stick" causing the car to idle at around 2500 rp...
