Search the Community
Showing results for tags 'p0301'.
  • Search By Tags
    • p0301 ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 5 results
  1. MY2000 C2 Tiptronic Cabriolet, stock intake, around 70k miles. I changed out the coolant tank about two weeks ago. During the tank install, I broke the oil filler tube. I wrapped it tightly with Gorilla tape as a few people had mentioned that as a temporary fix. I've driven the car a...
  2. Hi all The engine light comes on my 996 every so often, then goes off a few weeks later. I wasn't to concerned as the car drives well. So I got round to plugging it into the Durametric to look at the fault codes.... I've got loads of codes, P1340, P1531, P0300, P0306, P0304, P0...
  3. Hello all, This is a continuing repair to what started as a camshaft deviation out of spec leading to the replacement of the chain tensioner pads / brake pads / chain ramps on my 2000 911 - 996 5-Chain engine. Seen here: That odyssey has since been resolved but I now have a new issue. Quick...
  4. G'Day... new to forum and my first 911 after 40 years of dreaming and running too many various hot VW's and rotors : ) I have an early 2008 Australian delivered Carrera 2S that had a engine light - go to garage - come on after a rough idle and stall at the lights. I have done nearly 6000 k's sin...
  5. My 2000 Boxster S w/105k (body) 40k (engine) is acting up. Last fall, I got caught in downpour and inches of standing water, getting splashed hard by other cars. The CEL started flashing and the car was nearly impossible to drive past 3rd gear (no power and bucking) until I could get off freeway t...
