Search the Community
Showing results for tags 'p0223'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. What could be causing the attached faults simultaneously? I parked the car last night - this morning it would not start. I checked and cleaned (contact spray) the DME connectors to no avail. In the past, I had a few occasions when the throttle would "stick" causing the car to idle at around 2500 rpm. Moving the DME connectors around would solve it (I assumed a bad contact on one of the signal cables). I have also checked all the fuses and the plug to the throttle body. The live values on Durametric do not change, no matter how I press the gas pedal. Normally, they will vary - e.g., "Pedal Value" going from around 0%, to 100%. Now, Pedal Value is stuck at 30%. Of note, but I don't believe it is relevant: The engine is an M97.21, the car has been running fine with it since 2010 (I reprogrammed the original DME myself). Any suggestions on how to approach this would be greatly appreciated. I am at a loss since the faults suggest a problem on both ends (pedal and throttle plate). I tried my best to ensure good contact for the wires plugging into the DME - I even removed each of the two "sections" that slide into the safety clip and checked that each wire is pushed all the way forward and locked. I am assuming it is extremely unlikely that the DME itself can go bad only in the circuitry involving the e-gas? EDIT (per the suggestion of JFP below): The car is a 2003 986 s. No modifications to the wiring harness, with the exception of an extension to control the M97.21 engine's two-stage valve lift.
