Search the Community
Showing results for tags 'p0112'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. 1999 Porsche Boxster 986 shows check engine light (CEL). Code read at autozone as P0112 Error Code (Intake Air Temperature Circuit Low Input). According to <http://repairpal.com/obd-ii-code-p0112>, the error code causes could be Defective Intake Air Temperature Sensor (IAT) Dirty air filter Defective Mass Air Flow Sensor (MAF) Faulty or corroded Intake Air Temperature wiring or connection MAF: Bosch 996 606 123 00​ (serial number?:0 260 217 007) DME: Bosch 996.618.601.04 (serial number?:0 261 204 605). Lots of other numbers on DME. Can post image if required. After doing some research, I did some basic digital multi-meter tests between the MAF, IAT, and DME (MAF/IAT are combined into one unit in the '99 Boxster). NOTE: Engine Control Unit (ECU) seems synonymous or very related to DME or Digital Motor Electronics in the Porsche Boxster, Boxster S Service Manual: 1997-2004 by Bently Publishers {ISBN-10: 083761645X -- ISBN-13: 978-0837616452} I detached the MAF cable from the MAF, and I uninstalled the Engine Control Unit (ECU) from the trunk wall and detached the ECU cable from the ECU. I then measured the resistance between the following terminals. These results were: MAF 1 to DME 15: 0-0.5 Ohms MAF 2 to DME 54: 0-0.5 Ohms MAF 3 to DME 45: 0-0.5 Ohms MAF 4 to DME 47: 0-0.5 Ohms MAF 5 to DME 17: 0-0.5 Ohms Based on the pinout of the MAF to DME, and according to Porsche Boxster, Boxster S Service Manual: 1997-2004 by Bently Publishers, I have a DME version 5.2.2. I'll have to update what the service manual descriptions of these terminals are tonight when I am near the book again. Then, with the MAF re-installed and the DME re-installed and all cables reconnected, I measured the following values: Engine @ idle, MAF 4 to MAF 3 is 5v. Engine @ idle, MAF 1 to MAF 3 is 3volts Engine @ idle, MAF 2 to MAF 3 is 13.6volts. Engine @ idle, MAF 3 to car ground is shorted. Engine @ idle, MAF 3 to MAF 5 is 1.38V. Engine @ 3000 RPM, MAF 3 to MAF 5 is 2volts. From these measurements, it appears as though the MAF is running properly. Could someone confirm? Other tests/info: I cleaned the MAF with MAF cleaner, which had no effect. I drove the car with the MAF cable removed from the MAF and the car drove exactly the same as with the MAF cable connected. I bought the car with the P0112 error code showing, so I don't know what the car drove like without it. That said, the car does not have difficulty idling and is definitely faster than my 2008 Corolla LE. I can't say if it is as responsive or as quick as it should be, however. To try to find vacuum leaks, I sprayed carburetor cleaner on literally everything I could see in the engine with the top engine cover removed. the engine speed did not change from idle at any point during the carburetor cleaner test did. With the engine off, the MAF removed, and the air temp around 60-70°F, I measured the MAF terminals below. MAF 1 to MAF 3 is 1.7 kOhm. Maf 2 to everything is either open loop or megaohms. Then, with engine still off and the MAF removed, I breathed on the thermistor and read the following values: MAF 1 to MAF 3 is 1.4kOhm Maf 2 to everything is either open loop or megaohms. Based on a DME 7.8 manual, the IAT is supposed to read 2.3-2.7kOhms at ~20°C. Which would put the resistance of my IAT (1.4-1.7kOhms) a little low. Does anyone have a DME 5.2.2 manual to confirm what the resistance of IAT (pin 1 to 3) should be? If this resistance is OK, then does anyone have ideas as to what else the problem could be? It seems like my current options are: Replace MAF (~$250 <http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=996-606-123-00-M14&catalog_description=>) Vacuum system smoke test Re-flash DME (~$400) Replace DME(~$1000 min) ​I've read bad things about using after-market MAF's, so I will only be replacing w/ official MAF if that is the correct path to take.
