Search the Community
Showing results for tags 'oil leak'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 6 results
  1. Need help to understand what kind of oil leak i have on my car, picture attached. Oil even on the inside of those Rubber Sealing Plugs on bottom of Automatic Trans (Carrera 4 with tiptronic 2002)
  2. Hi Everyone, I am intrigued. Attached is a photograph of an oil leak from the front of the engine of my 2010 Boxster S. The pics show the front upper and lower oil pan just below the front engine mount when the leak was at its worst. Of course this is the 3.4 DFI engine, the car is pristine and has only covered 33,000 kms. The history is that the leak was diagnosed as a faulty AOS at the last service a month ago and the AOS was changed. But the leak persisted, not a lot, occasionally a spot on the garage floor but not always. Looking from above and from behind the front seats the engine appeared to be completely dry above the upper oil pan. Also the PDK had become very sluggish and unpredictable when taking off from a standstill but otherwise the car appears to run fine. When I reported back to the dealer they advised that both problems were caused by the AOS. They said that the new AOS was a faulty part and happily agreed to replace at no cost. This has now been done and after a hot 250 km run the leak has stopped but there is still some oil residue around the lower pan. But nothing like in the attached picture. The dealer advises that this is oil leaking from the intakes left from the bad AOS and that it will clear over time. Miraculously the PDK is back to perfection so I guess the dealer knows his stuff. But does this make any sense?
  3. Happy Thanksgiving, Folks! Appreciate your thoughts on this situation. I'd been noticing infrequent leaks - looks like oil but doesn't seem as thick or viscous, from the rear suspension area of the driver's side. I checked the oil levels on both the dash indicator (varies between at the MAX level to mid-way between MAX and MIN levels) and the dipstick which is higher than mid-way. I'm not so sure if this is really oil but is brownish and smells like a mixture of dirt and water. I peeked under the car and have attached photos of the leaky area and it's cleaner sibling on the opposite end on the passenger's side rear suspension. 1) What is this part that is leaking? Is that really oil? 2) Can this leak be plugged or should the part be replaced? 3) If it is the struts, time to swap the rears out too? I'm looking at the fronts soon, so wondering if it is time to replace all 4? Here is the leaky part - on the rear of the driver's side. Here is the clean part on the rear end of passenger's side Thank you for your valuable time here during the holidays. Cheers, Vish
  4. Started to change oil on my cayenne turbo and found major oil leaks on front right side. Oil was almost driping from generator/alternator. But as everything is built so tight together it is allmost impossible to locate the cause. I think if it would be the turbo it would be more back to the car? Any suggetion what to look for or how to identify the oil leak location? K.
  5. Hello there, my car is an early 2004 996 C4 Cab, 3.6L, 85k miles. Good stuff on my DropBox folder: https://www.dropbox.com/sh/p62gwxshg2zath4/0wYS9yrgfv Engine has not been started for 4 months. Actually it has been on a huge container for 2+ months and just few weeks ago I got the time to start working with my car again. Just before taking these pictures, note that I did wash my engine and transmission while they were still connected to each other, that might explain the glossy oil spots near my IMS (or not). Four months ago, underneath the car it looked that I get a tiny amount of oil after I drive around 500 miles, sometimes even a drop of oil to my garage floor if I drive a lot more. The drop comes right to the spot which usually indicates RMS/IMS leak. Then again, my AOS has been spitting lots of oil out from the connectors and the drop might originate from there too, impossible to say as front left side of the engine near AOS was so full of oil and gunk. I've changed my oil now twice, both the oil and filter ripped open has looked really really clean but this is based solely on human eye :-) I'd like to get a few second opinions to my questions, hopefully this thread is usefull to others too. 1) How does my RMS / IMS look in general? I'd say the leak is reasonably small, most gunk originates from clutch, would you feel the same? 2) Would you change my RMS or just leave it be? It has already been changed once at some point. 3) What exactly seems to be leaking here? To me it seems to be the IMS, but strangely enough the bottom part right below the IMS cover was completely clean (just zoom the images and remember that I washed my tranny and engine just before separating them). 4) Which bolts would you change while doing the IMS? Looking at the pictures, many change bolt numbers 4, 5, 6 and 7, how about you? 5) Curiosity question, what parts are not original? My RMS must be new as the part number is 997.101.212.00. IMS looks old, part number K.99602401 (?). Also would you also feel that many of these bolts have been changed as they look past year 2004 bolts, right? PS. I have a new RMS, LN bearing + tools waiting for the installation.. Big Kudos to everyone who got this far, hope you'll inspect my DropBox picture folder too!
  6. Hi, I'm looking to buy a Boxster S (02-03) and have found one fairly cheap 2002. The car has previously been in an accident of some kind, but has been repaired properly. A got a car inspection performed and the following issues were outlined: 1. Oil leak coming from both rocker covers (fairly minor leak) 2. Oil leak coming from centre of engine block area (fairly minor leak) 3. Outter drive shaft boot split (I've read this is fairly common, and needs replacing) 4. Some knocking noise in front and rear suspension during test drive The inspector said he thought the car was actually in pretty condition. And I've driven the car and it drives well and looks to be in fairly good condition. (1) The car has been garaged and not driven for two years prior to the inspection, which I thought may have led to the drying out of the rocker engine gaskets, and hence oil leaks. (2) I'm fairly worried about centre of engine block leak, as nothing is cheap to rectify on a Boxsters engine from what I've read in these forums. And I haven't found any mention of this issue in the forums. (4) I think the inspector was being overly fussy with this, as it looks like the car has the original suspension etc. Thoughts? As the car is selling for a responbly good price, I wanted to get some feedback as to whether I should be alarmed at the issues above and run a mile, or consider purchasing. And on purchasing whether these need immediate attention. Thanks in advance, Darren
