Search the Community
Showing results for tags 'obddoctor pro'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. My car is a 2005 911 base model 997. I had a tune installed and am having some issues with it. I only had the tune done because I put high flow cats on the car and had a stumble. The tune company is wanting a data log with the following actual values. 1. Engine RPM > 2. Injection Time/Injection PW > 3. Ignition Angle > 4. Pedal Position > 5. Actual Throttle Plate Angle > 6.Actual Lambda Value Bank 1 > 7. Mean Fuel Trim Bank 1 > 8. Actual Lambda Value Bank 2 > 9. Mean Fuel Trim Bank 2 I started out trying to get this done with Durametric. The first obstacle I ran into was Durametric did not have compatibility with the variant on my ECU. I called their support and they were able to quickly get this resolved. The problem that I have now is that I don't have any actual values for the Actual Lamda Value for Bank 1 or Bank 2. Durametric basically told me that they have nothing to do with the values and if its not in there they can't help me. The following is all the Actual Values in Durametric that I have to choose from. 1. AC pressure 2. Actual Camshaft angle bank 1 3. Actual Camshaft angle bank 2 4. Actual throttle plate angle 5. Air Mass 1 (sensor) 6. Altitude correction Factor 7. Ambient Pressure from DME 8. Ambient temperature 9. Camshaft deviation bank 1 10. Camshaft deviation bank 2 11. Catalyst Monitoring time bank 1 12. Catalyst monitoring time bank 2 13. DME supply voltage 14. Distance towards power failure 15. Distance with check engine on 16. Driving cycle counter 17. Engine compartment temperature 18. Engine compartment temperature (sensor) 19. Engine load 20. Engine load (SAE 1979) 21. Engine oil temperature 22. Engine oil temperature (sensor) 23. Engine roughness cylinder 1 24. Engine roughness cylinder 2 25. Engine roughness cylinder 3 26. Engine roughness cylinder 4 27. Engine roughness cylinder 5 28. Engine roughness cylinder 6 29. Engine speed 30. Engine Start temperature 31. Engine temperature 32. Engine temperature (sensor) 33. Exhaust temperature stream 34. Fuel Level 35. Fuel Level adaption at close idle (RKAT) 36. Fuel Level adaption at close bank 2 37. Fuel trim adaption lower load (FRAU) 38. Fuel trim adaption lower load (FRAU) 39. Fuel trim adaption lower load (FRAO) 40. Fuel trim adaption lower load (FRAO) 41. Fuel trim mean value 42. Fuel trim mean value 43. Idle speed specified RPM 44. Ignition angle 45. Ignition counter misfire direction 46. Ignition map RON department 47. Ignition Safety retardation 48. Injection time 49. Intake air temperature (sensor) 50. Intake- air temperature 51. Lambada controller delay time 52. Lambada controller delay time 53. Loss adaption 54. Mass airflow (MAF) 55. Mass airflow (hot film MAF + tank vent) 56. Misfire counter cylinder 1 57. Misfire counter cylinder 2 58. Misfire counter cylinder 3 59. Misfire counter cylinder 4 60. Misfire counter cylinder 5 61. Misfire counter cylinder 6 62. Misfire detection adaption 0 63. Misfire detection adaption 1 64. Misfire detection adaption 2 65. Misfire Range 66. Misfire Range 67. Misfire Range 68. Misfire Range 69. Nominal Camshaft angle bank 1 70. Nominal camshaft angle bank 2 71. Nominal Throttle Plate angle 72. O2 sensor downstream 73. 02 sensor downstream 74. Operating time since power fail 75. Oxygen sensor (LSF) Voltage ah.ofcatc.1 76. Oxygen sensor (LSF) Voltage ah.ofcatc.2 77. Pedal Encoder potentiometer 1 78. Pedal Encoder potentiometer 2 79. Pedal Value 80. Radiator fan request Value 81. Relative fuel quantity via tank ventilation 82. Relative secondary air mass 83. Retardation cylinder 1 84. Retardation cylinder 2 85. Retardation cylinder 3 86. Retardation cylinder 4 87. Retardation cylinder 5 88. Retardation cylinder 6 89. Tank ventilation valve 90. Throttle potentiometer 1 91. Throttle potentiometer 2 92. Timer as end of starting 93. Transmission oil temperature 94. Vehicle speed 95. Warm up counter Charcoal canister load I am looking for other means to get a quality data log. I have just purchased an ODBlink MF wi-fi unit. I also have a few phone apps like Torque Pro, OBDdoctor pro, and OBDLink. The problem I am having is they have several Lambda PID's to choose from and am not sure witch ones to use. If anyone has suggestions it would be greatly appreciated. even if the solution is using a totally different data logger.
