Search the Community
Showing results for tags 'misfire dtc error camshaft'.
  • Search By Tags
  • Search By Author
  • 911
  • Boxster
  • Cayenne
  • Macan
  • Panamera
  • Taycan
  • Classic Porsches
    • 356 Series
    • 911, 912 Series
    • 914, 914-6 Series
    • 928, 928S Series
    • 964 Series
    • 993, 993 TT Series
    • 980 Carrera GT
    • 918 Spyder
  • Events / News
    • News, Information, Rumors
    • Events
    • Work on Cars (SF Bay Area)
  • Other
    • Lost Radio Codes
    • Workshop Tools
    • Porsche Trivia
    • Forum Features Explained
    • Post Testing
Categories
  • Contributing Members Only
    • Tools and Diagnostics
    • Other files/documents
  • Public
  • Option Code Documents
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan
    • Panamera
    • 918 Spyder
    • Turbo / GT2
  • Service and Wear Parts List
    • Boxster
    • Carrera (911)
    • Carrera GT
    • Cayenne
    • Cayman
    • GT3
    • Macan (95B) (MY2015 - 2018)
    • Mission E
    • Panamera
    • 918 Spyder
    • Turbo / GT2
Categories
  • 911
    • 992-2 (911 Carrera) - DIY
    • 992-1 (911 Carrera) - DIY
    • 991-2 (911 Carrera) - DIY
    • 991-1 (911 Carrera) - DIY
    • 991 (Turbo, Turbo S) - DIY
    • 997-2 (Carrera) - DIY
    • 997-2 (Turbo) - DIY
    • 997-1 (Carrera) - DIY
    • 996 (Carrera) - DIY
    • 996 (GT3) - DIY
    • 996 (TT/GT2) - DIY
    • 993 (Carrera,Turbo) - DIY
  • Boxster
    • 718 (Boxster, Cayman) - DIY
    • 987-2 (Boxster/Cayman) DIY
    • 986 (Boxster) DIY
  • Cayenne
    • 9YA (Cayenne) - DIY
    • 92A (Cayenne) - DIY
    • 9PA, 9PA1 (Cayenne) - DIY
  • Macan
    • 95B-2 (Macan) - DIY
    • 95B (Macan) - DIY
  • Panamera
    • 971-2 (Panamera) - DIY
    • 971 (Panamera) - DIY
    • 970 (Panamera) - DIY
  • Taycan
    • Taycan Turbo, Turbo S - DIY
Categories
  • Cars For Sale
  • Parts for Sale
  • Tools for Sale
  • Items for Trade
  • Wanted
Product Groups
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Interests
From
Present cars
Future cars
Former cars
Found 1 result
  1. Hi, I recently bought a 05 CTT with 80k miles. It was running a little rough, so I changed the plugs, under seat battery and a coil pack that was giving an intermittent misfire code on cylinder 3. Today, after a 75 mile highway drive, the Check Engine light came on. I pulled the following codes with Durametric, any ideas what I need to check? Bosch Digital Motor Electronics 7.1.1 Current Fault Codes P0344: Camshaft Position Sensor "A" Circuit Bank 1 or Single Sensor - No signal/communication, test conditions are not-completed, fault is not currently active and is not causing a DTC light P1119: Implausible signal, test conditions are not-completed, fault is not currently active and is not causing a DTC light P1119: Implausible signal, test conditions are not-completed, fault is not currently active and is not causing a DTC light P0016: Crankshaft Position Camshaft Pos. Correlation Bank 1 Sensor A - Value below lower limit value, test conditions are not-completed, fault is currently active and causing a DTC light P2329: Air Leak Between MAF and Throttle Body - Upper limit value exceeded, test conditions are not-completed, fault is currently active and is not causing a DTC light P0300: Random/Multiple Cylinder Misfire Detected - Implausible signal, test conditions are not-completed, fault is not currently active and is not causing a DTC light P0303: Cylinder 3 Misfire Detected - Implausible signal, test conditions are not-completed, fault is not currently active and is not causing a DTC light Porsche Stability Management (PSM/ABS) Current Fault Codes 1314: DME control module. Please read out fault memory Vehicle Electrical System Current Fault Code (red exclamation but no error message) I am not an expert with the Durametric, so I couldn't see how to get more info on the PSM and Vehicle Electrical System codes.
